Removing the autorouter changes is fairly easy, in pcb view click routing-> select all traces like this
then hit the delete key to delete all the traces. Then you need to do the same to the vias that autorouter added like this
and again hit delete. That takes you to a clean version of pcb view with the rats nest lines visible where the traces should go. At this point you can add the part for the Tracor power supply (which likely needs the same capacitors on input and output that are in my 7805 sketch) and make those changes in breadboard and schematic. The wire jumpers are available in core parts here
Once in the sketch clicking on either pad and dragging it will extent it
Normally you don’t need wire jumpers although in some cases they are the easiest solution. Most of the time you want to add a via to the sketch and then break a trace and attach it to the via like this. This won’t work because both traces are on the bottom layer and they will short to each other.
so I need to drag a via in and split the wire so it can change layers at the via like this first drag the trace up to create a bend point  like this
then drag a via in to the sketch like this
then right click on a middle segment and select delete wire up to bend point to separate the traces
like this
now drag the end of the cut trace to the via
so it connects like this
now we want to delete the trace on the bottom layer with the red arrow and use the rats nest line from the via to make a trace on the top layer to the final destination like this
You keep doing this until the entire board is routed. You usually have to back track and experiment with routes til you successfully connect all the rats nest lines to where they are supposed to go.  It gets easier with experience but the only way to get the experience is to do it.
Das Entfernen der Autorouter-Änderungen ist ziemlich einfach. Klicken Sie in der PCB-Ansicht auf Routing → wählen Sie alle Spuren wie folgt aus
Drücken Sie dann die Entf-Taste, um alle Spuren zu löschen. Dann müssen Sie dasselbe mit den Vias machen, die der Autorouter wie folgt hinzugefügt hat
und drücken Sie erneut die Entf-Taste. Dadurch gelangen Sie zu einer sauberen Version der PCB-Ansicht, in der die Rattennest-Linien sichtbar sind, wo die Spuren hingehen sollten. An diesem Punkt können Sie das Teil für die Tracor-Stromversorgung hinzufügen (die wahrscheinlich dieselben Kondensatoren an Eingang und Ausgang benötigt wie in meiner 7805-Skizze) und diese Änderungen in Steckbrett und Schaltplan vornehmen. Die Drahtbrücken sind in den Kernteilen hier verfügbar
Wenn Sie in der Skizze sind, klicken Sie auf eines der Pads und ziehen es, um es zu erweitern
Normalerweise brauchen Sie keine Drahtbrücken, obwohl sie in manchen Fällen die einfachste Lösung sind. Meistens möchten Sie der Skizze eine Durchkontaktierung hinzufügen und dann eine Spur unterbrechen und sie wie hier an die Durchkontaktierung anhängen. Das funktioniert nicht, da sich beide Spuren auf der unteren Ebene befinden und sie miteinander kurzschließen.
also muss ich eine Durchkontaktierung hineinziehen und den Draht teilen, damit er die Ebenen an der Durchkontaktierung wie folgt ändern kann: Zuerst die Spur nach oben ziehen, um einen Knickpunkt wie diesen zu erstellen
dann eine Durchkontaktierung wie diesen in die Skizze ziehen
dann mit der rechten Maustaste auf ein mittleres Segment klicken und „Draht löschen“ bis zum Knickpunkt auswählen, um das zu trennen Spuren
so
ziehe nun das Ende der abgeschnittenen Spur zur Durchkontaktierung
so dass es so verbunden wird
jetzt wollen wir die Spur auf der unteren Ebene mit dem roten Pfeil löschen und die Rattennestlinie von der Durchkontaktierung verwenden, um eine Spur auf der obersten Schicht zum endgültigen Ziel wie diese
Sie machen so weiter, bis die gesamte Platine geroutet ist. Normalerweise müssen Sie zurückgehen und mit Routen experimentieren, bis Sie alle Rattennest-Linien erfolgreich mit ihrem Ziel verbunden haben. Mit der Erfahrung wird es einfacher, aber die einzige Möglichkeit, Erfahrung zu sammeln, besteht darin, es zu tun.
