Please help me find this part.
Arduino Nano CNC Shield V4
Thank you so much
There doesn’t appear to be a Fritzing part for this and not enough information here to make one. We would need a web site with the dimensions (which are here) and the connector information (which is not) to make such a part.
Maybe this information will work.
https://wiki.keyestudio.com/Ks0152_keyestudio_CNC_Shield_V4
Or need more technical specifications?
keystudio-Ks0152.fzpz (31.7 KB)
Note pcb view is suppressed as not being useful and if you wish (and with some effort) add the A4988 and Nano, to the sketch and “install” them in breadboard like this. First you need to set the grid size to 0.025in
as the pins don’t align on 0.1in boundaries. Then drag the A4988 and Nano parts in from core parts (note the connections are red to indicate not connected.)
then move the part (moving the shield will not work to make a connection) until all the pins light green to indicate they are connected to the shield
then in schematic the A4988 and Nano parts appear with rats nest lines to the shield ready for routing.
The layout isn’t perfect because the original parts aren’t designed for this particular use but it works with some effort.
Thank you. This is what was needed
Pour moi j’ai besoin d’une driver DM556 et une CNC shield V3 pour faire du schéma avec fritzing
A google search of the form "fritzing part ardino nano CNC shieid V3 " turns up this part:
A google search for “fritzing part driver dm556” turns up this post which may do
via google translate:
Une recherche Google du formulaire “fritzing part ardino nano CNC shieid V3” fait apparaître cette pièce :
Une recherche Google pour “fritzing part driver dm556” fait apparaître ce message qui peut faire l’affaire
