Hi! I’m new here and I love this app already!! I was wondering if any one has a part file for Arducam Multi Camera Adapter Module V2.2?
While such a part could be made, I’m not sure I see the use for it. The GPIO pins are the only ones that will connect to anything as the camera connectors aren’t populated on any of the PI cpu boards in Fritzing. As well there is little documentation (and what there is is unclear) for the board.
appears to say that only GPIOs 7, 11, and 12 are used, but the diagram above it indicates a lot more pins (but no power or grounds) connected. So unless there is better documentation somewhere I expect a Fritzing part is unlikely.
While I don’t think this is likely to be useful, it should do what you want.
Arducam_Multi_Camera_Adapter_Module.fzpz (20.7 KB)
Thank you so much! I just need the breadboard view for now so this should work! Thanks again
