I just published a pre-release. I don’t have the means to support XP or 32 bit versions. So currently, four builds are done: Linux 64 bit (recent Linux distributions >= 2016 should be good), MacOS High Sierra and Maverik, Windows 10 , 64 bit.
The Windows 10 version might or might not run on older versions, I don’t have the resources to test it or to maintain an older windows toolchain. Some problems might be easy to fix, so it would help if you try it, and leave me a note how it worked (create a new thread or issue on github). Look for the latest pre releases on github, e.g.
Once the release is finished, it will also be published via github first.
Greetings, Kjell
