If some can help me to the fritzing module
Name: 4.0inch Capacitive SPI Module ST7796
No. The image is unreadable a pointer to the web site where the datasheet is available may be a better bet. A google search of the form “fritzing part 4.0inch Capacitive SPI Module ST7796” should turn up any existing parts.
It doesn’t appear there is an existing part, so you would need a custom part. That is likely to be a while as there is somewhat of a backlog of requests at the moment.
Where do submit for custom parts?
You already have. It will appear when I get to it.
This part should do what you want. Of note is the mounting holes in pcb are not drilled by default. If you want the mounting holes drilled you need to drag a hole from core parts/pcb in to the sketch and align it on every mounting hole you want drilled (they are marked on silkscreen) and set the appropriate hole size.
4in-spi-lcd-display.fzpz (5.3 KB)
