I generated a Gerber file and noticed that the PCB is missing the holes for the support to be attached with screws. The file in question is ‘1x_18650.fzpz’ (7.8 KB)
E.g. Imgur: The magic of the Internet
Kind,
Dacian
Kind,
Dacian
That is intentional. If you want the mounting holes drilled you need to drag a hole part from pcb in to the sketch
and then set the size correctly in Inspector.
If you don’t want the mounting holes you would need to modify the part if they are in the part.
Thank you very much for your advice.
