2-Pin Terminal Block Part
I often use 2-pin terminal blocks (screw-type) and simply use 2-pin female headers.
I know there are some posted but, I generally prefer to make my own parts (especially if there are no images posted with parts that others make) and won’t bother to download them to see the part.
Thus, I made a 2-pin terminal block part…
Terminal 2pin.fzpz (5.5 KB)
2-pin_photo
37%20AM
Yes, I also love to create my own parts… :grinning:
I already posted some Terminal Block Parts as your pix…
You can check here, “35 New & Edited Parts
There are also 3 pins and other sizes submitted…
In your parts, I think the part name “TRM” is unnecessary… And in the PCB the Hole diameter is only 1mm, should be little bigger… It’s just my personal opinion…
