DFRobot wireless charger pls. i only need e connections and PCB image thing for the breadboard view, that’s all
A google search of the form “fritzing part Wireless Charging Module 5V/1A dfr0362” turns up this post from the past:
The suggestion here may work. If it doesn’t you would need a custom part (in which case repost and I will make one.) This method is easier if it works for you.
