DFRobot wireless charger pls. i only need connections and PCB image thing for the breadboard view, that’s all
Did you read the rely to your last post? If not please do so instead of reposting.
I did read but I could not find any fritzing part
There is no fritzing part at present. You can do what you want by using a generic header. That will give you connections to the wires in breadboard, schematic and pcb to use as you wish. If that doesn’t do what you want then a custom part would need to be made. You should have replied in the original thread if you didn’t understand what was being said, posting a duplicate request with no further information isn’t helpful.
Since I suspect you don’t know what I am talking about, here is what I am suggesting:
drag the generic connector from core parts (which by default has two pins which is what you need) in to the sketch. Here I changed the connector from female (the default) to male in Inspector (the lower right window) but either will do as pcb is identical. That gives you two pads for wires in pcb and connectors in both breadboard and schematic to do whatever you need with.
no that’s not what I need, i want like the whole PCB and the coil as a fritzing part. i need this cause I am creating picture schematic like this:
Thanks a lot, is there a way to decrease the size of the components in the menu for like any component?
AFAIK size changes require changes to the part and the parts are at life size now (as they should be.) So the answer is likely no.
