Hi
Does anyone know when Fritzing might be able to be installed on a Windows11 ARM64 machine? I have a MS Surface Pro 9 that i’d like to use Fritzing for, but it wont install as the processor is an ARM64? If there are any known workarounds that can get it working then i’d be keen to know.
I see you have found the github thread on this topic. I don’t know if this will work on Arm, but it is worth a try (I believe this must be in the Fritzing installer and therefore may provide a log on Arm)
Awesome, thank you. I will check it out!!! I’m being a bit thick, but I do I have to pay again for this or is there someway to doanload it with the licence i’ve already purchased? If so I can’t seem to find a way aroudn the paypal link to download?
