Hello again! Im search the esp32 wrorher-e (only processor) birinde bu işlemci varsa lütfen atsın
@Team_Of_TECH_Leader Hi ya you know what I’m gonna say right?
vanepp
June 1, 2025, 12:13pm
3
Presuming you are looking for a esp32-wrover-e chip only there is one here (as usual a google search of the form “fritzing part wrover-e” will find it)
This should do what you want. Note the thermal vias are not in pcb as Fritzing can’t produce holes in an SMD part (no copper0) so you will need to drag vias in to the sketch to add them:
[capture]
[capture1]
the red circles are vias (presumably to a copper pad on the other side of the board although that isn’t said, only implied) and would need to be added to the sketch like this:
[capture2]
Note that DRC complains about overlap on the vias which in this case can be ignored.
ESP32-WROVER…
