I’m looking for the generic header part where you take a 40-pin header and break off as much as you happen to need. I’m sure it’s there because I’ve seen it in other diagrams like this one: https://cdn.hackaday.io/images/3881161433706316298.PNG
You pick the header in Core parts, and you go to the Inspector panel below the parts bins and select the number of pins, male/female, etc.
Thanks! I’ve found it in the “Connection” section.
Ohh you wanted that actual part.
It’s not a very good icon, but if you get stuck just type it in the search box in the parts bin section - the magnifying glass button - and it should turn up.
