What is the output voltage range?
What is the output voltage range that can be programmed on the TPS7A8500RGRR?
The data sheet here (which a google search would have found you and not required this post!)
Indicates it is either 0.8V to 3.95V or
0.8V to 5V (in the other mode.)
