I took a picture of the Yellow fan from the kit used Gimp and 3d paint to edit it then used pngtosvg.com to convert it to an .svg file. Then resized the file with https://products.aspose.app/imaging/image-resize Then loaded the image into parts editor and changed all the metadata etc to fit what my new part is.
Between converting from PNG to SVG file the background or artboard became white again.
here path10 is moved away from the image. It does nothing useful so deleting it won’t hurt anything but improves the image in Fritzing:
image with path10 removed (I also added the breadboard layerId so that your part will now export as an image, which it won’t without the breadboard layerId.)
