there is an element in some fzp files called “taxonomy”, e.g.:
<taxonomy>part.dip.14.pins</taxonomy>
what is this used for and what is the significance of the value? a quick scan shows this as the full list of values that appear in the standard parts library (excluding obsolete and parts-factory parts):
discreteParts.capacitor.ceramic
discreteParts.capacitor.elecrtolytic
discreteParts.capacitor.electrolytic
discreteParts.pcb.plain.arduino_mega_r3_shield
discreteParts.pcb.plain.arduino_shield
discreteParts.pcb.plain.arduino-intel-galileo-pcb
discreteParts.pcb.plain.arduino-intel-galileo-pcb/2
discreteParts.pcb.plain.raspberrypi-pcb-shape
discreteParts.pcb.plain.sparkcore-pcb-shape
discreteParts.power.power.acpower
discreteParts.power.power.dcpower
discreteParts.resistor.220
discreteParts.resistor.fsr
discreteParts.resistors.adjustable.potentiometer
discreteParts.sensor.heat.thermistor
discreteParts.servo
discreteParts.switches.pushbutton
microcontroller
part.devmod.36.pins
part.dip.108.pins
part.dip.128.pins
part.dip.14.pins
part.dip.16.pins
part.dip.26.pins
part.dip.4.pins
part.dip.44.pins
part.dip.50.pins
part.dip.54.pins
part.dip.6.pins
part.dip.8.pins
part.mystery.magical.7.pins
part.sip.2pins
prototyping.breadboard.breadboard.breadboard0
prototyping.breadboard.breadboard.halfbreadboard
prototyping.breadboard.breadboard.halfminusbreadboard
prototyping.breadboard.breadboard.tiny
(making that list also highlighted a couple typos and format inconsistencies, which leads me to believe that this value isn’t all that important. also, it seems… short.)
