What are your best practices for converting a Fritzing breadboard project into a reliable PCB?
I’ve been working on a few microcontroller-based projects, and one thing I’ve noticed is that getting a circuit working on a breadboard is often the easy part. Turning that prototype into a clean, reliable PCB is where things get interesting.
I use Fritzing for visualizing circuit connections and creating PCB layouts, but I’m curious about how others approach the transition from breadboard to PCB.
A few things I’m particularly interested in:
  • How do you check for incorrect connections before moving to PCB routing?
  • Do you usually complete component placement first or start routing critical signals early?
  • How much attention do you give to ground planes and power distribution in relatively small boards?
  • What’s your approach when a component footprint doesn’t exactly match the physical component?
I’ve also been exploring PCB design resources from PCBCool, particularly around layout practices and common PCB design considerations. It made me think about how much easier PCB development can be when these decisions are considered during the prototyping stage itself.
For experienced Fritzing users, is there a particular workflow or checklist you follow before sending your first PCB design for manufacturing?
I’d especially like to hear about mistakes you’ve encountered in your first few designs and what you learned from them. I think that would be useful for people moving beyond breadboard prototypes.
