Wemos esp32 Lolin
Don’t see one in a google search, unfortunately also don’t see a mechanical drawing or even a pinout list at a quick glance. It should be relatively easy to modify one of the existing parts with mechanical dimensions and pin outs (the schematic on their site would likely have the pin outs). If you have one and can provide the measurements of the mounting holes and connectors (or verify they are the same as one of the others) it is easy enough to make such a part.
This should do what you want. The third mounting hole isn’t in the pcb as I don’t know where it is exactly but everything else should be there …
Wemos Lolin D32.fzpz (16.6 KB)
