Anyone can help me to get this part :
https://www.waveshare.com/wiki/Motor_Driver_HAT
https://www.waveshare.com/motor-driver-hat.htm
Thank you
Thank you
OK here is a Waveshare motor driver part.
waveshare-motor-driver-hat.fzpz (23.5 KB)
as it is a hat it has no pcb, just breadboard and schematic. As well only the gpio pins that are used (5V, 3V3, SDA, SCL) on the GPIO pins are defined. The GPIO pins are set to female so if you drag an RPI part over the hat and align the connectors they will autoconnect and add the connections in schematic:
here the hat is aligned on a RPI 3. In schematic the power, SCL and SDA connections are made:
Awesome! Thank you very much Peter!
