Waveshare BME68x Environmental Sensor (BME688, I2C) Fritzing part
I would like to share a Fritzing part for the Waveshare BME68x Environmental Sensor board with the Bosch BME688 (gas, temperature, humidity and pressure). I could not find a part for this board, so I made one for an ESP32-C6 sensor shield and want to share it with everyone.
Please note: this is a community part, not an official Waveshare part. The drawing is made after the product photo; the sizes come from Waveshare’s wiki (https://www.waveshare.com/wiki/BME688_Environmental_Sensor).
Download: Waveshare_BME688_Environmental_Sensor.fzpz (6.9 KB) - import it into Fritzing (File > Open, or right-click a parts bin > Import).
**About the part**
- Board 26 x 19 mm, drawn like the real board: header, mounting holes, BME688, level shifters, resistors and the PH2.0 connector.
- Only the 4-pin 0.1 in I2C header is a connector: SCL, SDA, GND, VCC, named like the board labels. The 6-pin PH2.0 connector is drawn but not connectable.
- I2C address 0x77 by default, 0x76 with ADDR low. The board has a level translator, so it works with 3.3 V and 5 V.
- Breadboard: the whole drawing is in the breadboard layer, pins exactly 0.1 in apart, the pin circles are the connectors themselves.
- Schematic: pins 100 mil long on the 100 mil grid, with terminal points at the pin ends.
- PCB: 4 through-hole pads (0.038 in holes), square pad for VCC (boxed like on the board). The board outline, the BME688, the PH2.0 connector and both mounting holes are in silkscreen, so you can see where the module sits on your board.
- The icon has its own svg file. In Fritzing 0.9.3b, a part whose icon reuses the breadboard svg can get its breadboard image replaced by another part’s when the sketch is saved and reloaded.
- Tested in Fritzing 0.9.3b: it loads in a sketch, and the breadboard, schematic and PCB views export as images and Gerbers.
License: CC BY-SA 4.0.
Feedback is welcome. If you see something wrong, please tell me and I will fix it.
