Hi Blue, I forgot the 8 pin version. Could you help me one last time?
ION
It doesnāt take much time, Big numberās pins already made,
160. Req - Terminal Block - wago 3.5 8p.fzpz (4.7 KB)
Great, THANK YOU!!!
Hi again!
After some time, i need to change my pcb and now I need the WAGO 250-202 instead of the 250-408 (which @Blue already made)ā¦
Both the 250-202 and the 250-408 are quite identical. The difference is in the pitch spacing (3.5 mm instead of 2.5 mm) and the number of pins.
@Blue or @vanepp,
is it possible for one of you to make this part for me? I would greatly appreciate it!
this is the link to the part
and this is the datasheet:
In the datasheet there are two versions, one with a straight line of pins and one with the pins offset upwards and downwards. I need the version with the offset pins (just like the version that @Blue already made.
Best regards, Jakob
Thatās not a problem⦠Just some PCB view adjustmentā¦
How many pins do you need�
Hi @Blue,
Thank you! Thats so cool and kind of you! I need two pins.
Very sorry for late reply, I totally forgot about itā¦
Here is itā¦
Req - Terminal Block - wago 3.5 2 (Camdenboss).fzpz (4.9 KB)
@Blue no worries=) THANKS=))
Hey @Blue, I just checked your part that you made with the two pins. I realised that the pins dont have the offset that I need.
This is what the part looks like now:
But the pins need an offset like this:
Here you can see two real pictures of the wago terminal block:
It would be great if you could change the part accordingly. Thanks=)
63. Req - Terminal Block - wago 3.5 2 (Camdenboss) (update).fzpz (4.9 KB)
Ok, try thisā¦
great! This looks good:-) Thanks
