I’m looking for .fzpz file of this MP3 codec. It is widly aviable and used in some intrestig (arduino etc.) projects.
The Adafruit equivalent has an other formfactor.
Thank you
This should do what you want. Note it needs the pcb footprint printed out at 1:1 scale and checked against the real board because the part was made from a jpg image (because there is no mechanical data that I can find on the net.) As usual the mounting holes are only on the silkscreen, if you want mounting holes drilled you need to drag a hole from core parts / pcb in to your sketch and set the size and position on top of the image in silkscreen.
VS1053-mp3-player.fzpz (12.5 KB)
