Voltage reguletor and v&a meter
xl4015-5a-ayarlanabilir-dc-dc-voltaj-dusurucu-dcdc-acdc-converter-acelex-49017-18-K
HELLO I WANT MAKE MY OWN POWER SUPPLY WİTH THİS PART BUT I NEED FRİTZİNG PART CAN YOU HELP ME PLEASE?
Not enough information here to identify this although it may be this part in core parts:
to find it enter rio rand in the search bar and hit enter. If you are making pcbs you need to check the footprint matches the part you have. Other wise again we would need a web site with the mechanical details of the part to make one.
thank for your answer but ı haven’t got this part??? can you export this part and send to me an .fzp file??
I can, but you would be better to do a parts update as it is in current core parts and thus you may be missing other things. First way to do a parts update is with Fritzing running click Help->check for updates. If that doesn’t work, then you need to do a manual update via the instructions here:
