HELLO I WANT MAKE MY OWN POWER SUPPLY WİTH THİS PART BUT I NEED FRİTZİNG PART CAN YOU HELP ME PLEASE?
I don’t think one of these exists. There are voltmeter modules and ammeter modules but not the combined one that I can find. Again we would need a web site for the part you have (with a wiring diagram) to make a part.
edit: Instead of making a power supply, you may want to look at one of these
It takes up to 20V in (I use a laptop 20V wall wart) and is adjustable with a built in voltage and current display. There isn’t a Fritzing part (yet
) for them either but I will likely eventually make one.
This doesn’t give the size of the module. Do you have the url you bought it from? That will likely have dimensions.
İt is amazing! thank you very much
