Hi, I am using this VICOR voltage regulator (buck) and I wanted to know if anyone could help me insert it to Fritzing.
I think it’s useful since a lot of voltage regulators by Vicor are built the same (mechanically)
link to the website:
Can’t add the datasheet but because it’s a pdf and not a jpg but it’s in the website link.
This should do what you want. As always before ordering boards print the pcb footprint out at 1:1 scale and check it against a real part (as I don’ t have one!) If you want mounting holes you would need to drag a hole from core parts/ pcb in to the sketch and position it appropriately over the flanges marked in pcb.
v28c15t100bl.fzpz (6.7 KB)
