Why can’t I choose a via of 0.6 or 1.2 mm? It only takes integer numbers and will convert 1.2 to 12:
It’s a bug. When I change the language from German to English, it works, but not with German language. I used both . and , in German, but it will always convert to integer.
Report it here on github (although that is an odd one, the translations don’t normally affect code!):
What version are you using?
It was fixed a few years ago:
I am using 1.0.2 on Windows 11
Yes, I can reproduce the behavior in 1.0.2 (Windows) when I change the language to German. I will add comment in the issue to reopen it. Thanks for the warning!
