V1.0.1 install issue on WIN11 pro
I just tried to install the latest version on the soft (V1.0.1 for windows) and it ending with a lot of error messages and the install progress frozen at 14% with no response.
I tried :
  • to restart the computer,
  • remove the soft and reinstall it,
  • remove it again and clear the registry files, then install it back after had restarted the pc,
  • triezd an older version…
    The result is exactly the same.
Here after the error messages :
Can enybody help me there ?
Thanks !
Two suggestions, the failed install has likely corrupted the user directories, to fix that follow these instructions:
linux
~/Documents/Fritzing/parts
~/.config/Fritzing
Mac
~/.config/Fritzing
then retry the install. You look to be trying install on a network drive (from the onedrive message) this has created problems in the past (usually when the remote file system isn’t available) so selecting a directory on a local hard disk is a better bet. Hope this helps!
Solved thanks to you ! Thank you very much !
It was the file over Onedrive that was causing troubles.
Cedrick
