I searched the parts catalogue but didn’t find a USB A vertical connector PCB mount .
Could anybody be so kind to create this part please?
Kind Regards,
Gregory
Kind Regards,
Gregory
This part should do what you want. Of note the slots are implemented as circular holes (Fritizing as of 0.9.10 will do slots but I am too lazy) so you may need to check that the mounting pins will fit in the holes before ordering boards. The holes are 0.079in which I think should fit the mounting pins (the pins are not dimensioned in the data sheet!) The connection holes are 0.355in as specified in the datasheet.
FY09-vertical-USB-A-connector.fzpz (3.8 KB)
