Does anyone know if this part exists within fritzing and under what name this would be under?
Essentially it is a USB-C female connector that outputs 12V. But those also can deliver out 6V, or 15V or 20V.
Thank you for the help.
There are various USB to power modules around but likely not this exact one. We would need a web site with size and connection information to make a part.
edit: found a web site with a similar module (check the +/- outputs match your module!) so here is a part.
usbc-to-12V-module.fzpz (8.2 KB)
