USB 5V 20x5730 LED Board (LYB-3221)
Previous work, similar parts
Generic LED strip/module parts exist, but none matching this specific board layout (LYB-3221) and connector arrangement.
The part is a rectangular white PCB populated with 20 SMD LEDs (5730 type).
Connectors:
- Micro USB port: For 5V DC power input (VBUS and GND pins are relevant).
- Solder pads (+, -): Two through-hole solder pads for alternative 5V DC power input, marked “+” (VCC/Positive) and “-” (GND/Negative).
The image provided:
No formal PDF datasheet is typically available for such generic modules. Information is derived from product listings and visual inspection:
- Product Name (Vietnamese): Mạch 20 LED Siêu Sáng USB 5V
- Model (on PCB): LYB-3221
- LED Type: SMD 5730
- Number of LEDs: 20
- LED Color: White
- Supply Voltage: 5V DC
- Power Input:
- Micro USB port
- Solder pads (+ / -)
- Operating Current: Approximately 430mA - 470mA
- Features: Designed for illumination, e.g., model lighting, night lights, cabinet lights.
This module is a breakout board. For PCB view in Fritzing, it would require:
- Two through-hole pads for the solder connections (+ / -). Spacing to be determined from the actual board (if a custom PCB is being designed to mount this module).
- Optionally, mounting hole(s) if present on the PCB (at least one is visible in the image).
- The Micro USB connector footprint is part of the module itself; for a Fritzing part, the VBUS and GND pins of the Micro USB would be represented as connectors, rather than expecting the user to solder a Micro USB onto their Fritzing PCB design to interface with this module.
