Updated design is not sent to PCBWAY
  1. Make design e.g. v1.1 and press Fabricate > PCBWAY > Open browser. v1.1 is seen in the PCBWAY website.
  2. Update design to v1.2, save, press Fabricate > PCBWAY > Open browser. v1.1 one is still shown in the PCBWAY website and not the updated design.
Expected the updated design to be sent to PCBWAY. In the processing window it seems like the zipping process goes very fast/skipped, so I am thinking it does not zip the updated design and just sends the old design to PCBWAY.
Fritzing 1.0.4
MacOS Sonoma 14.7.1
You would be better to open an issue here:
the developers do read the forums, but the official bug reporting site is github.
Thanks a lot, will try that.
You may also want to upgrade to Fritzing version 1.0.4 which was released lately. I don’t know if this was fixed there or not, but it is worth upgrading anyway for bug fixes.
I actually made a quick edit right after posting, I have upgraded to 1.0.4, though still the same issue.
Does the update leave you with a copy of the gerber files it sends? I don’t usually do boards and have never tried the order a board options.
No, you don’t see the copy of the gerber files it compiles. When you select Fabricate for PCBWAY, it shows a popup window where it compiles and zips the files, automatically uploads them to PCBWAY, and then you get a button that says Open in Browser. When you click that, it opens PCBWAY with your project/gerber files. You can try it without having an account or being logged in.
You then may want to try the standard gerber export (File->Export->For production->Extended Gerber) to see that the changes are being exported to there correctly. That may help in identifying where the issue is.
If I export Extended Gerber, then the files are exported correctly. I exported two versions with a text label saying rev1.1 and rev1.2. When uploaded manually to PCBWAY I also see that in their online visualizer. So, the problem seems to be with the “Fabricate” process when it is exporting/zipping the gerber files.
