it worked on previous version 3.5b but since i upgraded it does not work.
the contour file is blank
any help would be awesome. i love Frizing.
Check the path for elements that use scientific notation (i.e. something like 1.0-e4) there is a bug in 0.9.6 that won’t process scientific elements in paths. Fixed in 0.9.7 but that isn’t out yet. The work around is replace the -e entry with the equivalent integer value (which can be a pain!)
i made with inkscape and cant find any was to view path elements? is there a link for such an inspection. any help apreciated.
XML editor is your friend
this one doesn’t have any scientific elements but the idea is the same.
thanks that worked. opened with txt editor as the xml editor kept changing back to e-4 notation. i fixed in 4 spots and fixed. thanks you saved me a lot of struggle. it must be a bug in 9.6 as the previos versions had no problem. i also notice the contour file is still named wrong by default . it should be a gml file not gm1 as fritz makes it.
