Understanding Different Fritzing File Types
This topic is about different Fritzing file types
.fzpz
A zip file and a Fritzing part file type
Contains
.fzp
An XML file that stores the Metadata of the part
  1. Date
  2. Author
  3. Version no.
  4. Properties
  5. Tags
  6. URL
  7. Connectors
It is basically the backbone of the .fzpz file
Example:
<?xml version='1.0' encoding='UTF-8' standalone='no'?>
<module moduleId="..." referenceFile="..." fritzingVersion="...">
  <version>...</version>
  <author>...</author>
  <title>...</title>
  <label>...</label>
  <date>Mon/Tue/Wed/Thu/Fri/Sat/Sun MM DD YYYY</date>
  <tags>
    <tag>...</tag>
  </tags>
  <properties>
    <property name="variant">variant 1</property>
    <property name="family">...</property>
    <property name="part number"/>
  </properties>
  <description>...</description>
  <views>
    <iconView>
      <layers image="svg.icon.[...].svg">
        <layer layerId="icon"/>
      </layers>
    </iconView>
    <breadboardView>
      <layers image="svg.breadboard.[...].svg">
        <layer layerId="breadboard"/>
      </layers>
    </breadboardView>
    <schematicView>
      <layers image="svg.schematic.[...].svg">
        <layer layerId="schematic"/>
      </layers>
    </schematicView>
    <pcbView>
      <layers image="svg.pcb.[...].svg">
        <layer layerId="silkscreen"/>
        <layer layerId="copper1"/>
      </layers>
    </pcbView>
  </views>
  <connectors>
    <connector id="connector0" type="..." name="...">
      <description>LED Cathode</description>
      <views>
        <breadboardView>
          <p svgId="connector0pin" layer="breadboard"/>
        </breadboardView>
        <schematicView>
          <p svgId="connector0pin" layer="schematic" terminalId="connector0terminal"/>
        </schematicView>
        <pcbView>
          <p svgId="connector0pin" layer="copper0"/>
          <p svgId="connector0pin" layer="copper1"/>
        </pcbView>
      </views>
  </connectors>
  <url>...</url>
</module>
.svg - breadboard, schematic (, icon, PCB)
Part Graphics
.fzz
A zip file and a Fritzing Sketch File
Contains
.fz
An XML file that contains sketch info (position of parts and traces throughout the 3 views, namely breadboard, schematic and PCB)
It is basically the backbone of the .fzz file.
:warning::warning::warning: WARNING! HEADS UP! :warning::warning::warning:
A .fz IS NOT a sketch file. You can’t open a .fz file with Fritzing. Don’t get .fzz and .fz files mixed up!
.fzp
See ## .fzpz
See ## .fzpz
.fzbz
A zip file and a Fritzing Bin (library) file
Contains
.fzb
An XML that contains bin info (part icons, position of icons, order of icons, bin icon, and organisation of bin, e.g. separators)
A .fzb IS NOT a bin file. You can’t open a .fzb file with Fritzing. Don’t get .fzbz and .fzb files mixed up!
.fzp
See ## .fzpz
.svg- breadboard, schematic (, icon, PCB)
See ## .fzpz
That is good, but what is a .fz, .fzb and .fzp?
Click on the drawer :slight_smile:
Ah, Yes. I hadn’t seen that!
Thank you, very useful.
