This connector rocks!!! Please, I need the part.
This part should do what you want. Before ordering boards it would be a good bet to print the pcb footprint at 1:1 scale and compare it to a real part. The slots are implemented as holes which isn’t ideal but is all Fritzing can do (it can’t do slots in parts.)
Correct the two end pins to be shield instead of power, and increase hole size on the shield pins (which are slightly larger.)
usb-type-C-05-power-only.fzpz (4.1 KB)
Thanks, but check this, the only problem is that you put two positive pins, and must be just 1 positive, the two externals are for shield
it works for me, just because I will not use the shielding pins, I will order the part and feedback later when it arrives
Thanks a lot, you are really helping Peter!!!
Ah! I see my mistake. I read the positive and negative circled in green here as being both end pins, rather than the left most drawing that shows them as the shield. I will correct the part and reupload it. Actually wait for that before ordering boards because I think the shield pins also need to bigger now that I look more closely. They are currently all the size of the power pins and the shield needs to be larger (about 1.1mm it looks like instead of slightly less than 1mm.)
OK, fixed and uploaded. You will need to delete the part in your mine parts bin, (right click on it and click on remove part) then shutdown Fritzing answering yes to all the prompts to save the part and the part bin, then restart Fritzing and you should be able to load the new part.
Super nice! Thanks
Super, Thanks! Just what i was looking for.
This should be part of the default part libary!
