Type C cable
Shape and plug direction Small and slim, can be plugged in 2 ways
Transmission speed Up to 10 Gbps (USB 3.1 Gen 2).
Input + -
Insufficient information to do anything with, and likely no use in Fritzing anyway. In general USB connectors are not represented in Fritzing as no CPU boards I am aware of have the USB definitions defined making the cables not useful. If you have a specific use case you should present it.
