Hallo, I am using TTH 10 mm LED part but the holes are way to big and the spacing is not right of the holes. It would be bette the holes of a normal 5mm LED.
Can somebody update this part please?
Maybe this Fritzing part just doesn’t match your expectations for the LED you have. Because when I look at the data sheet for that part it seems quite accurate. One could argue that 2.4mm hole size for 2mm legs is big, but way too big doesn’t sound right. The spacing of the holes is spot-on with 5.08mm.
