Welcome aboard! This should do what you want. As always print out the pcb footprint at 1:1 scale and compare it to a real part before ordering boards. The pins holes are 0.038in (same as for a .1 header pin) which is slightly larger than what the data sheet specs the pins at.
edit: corrected this file to match the EI-3010-5-206 part
thank you for the nice greeting and the file.
Unfortunately, the transformer is one size too small.
I need the VB 2.0 / 2/6 from Block and there the connections are further apart.
Is there a second variant of the transformer?
for a better understanding here the data sheet with the transformer which I need:
There is now. I modified the part I made yesterday (and posted a corrected version above), since it exists now, and then changed it to this which should match the model you want:
