Noob question again. I have some potentiometers, header pins and an Arduino on a PCB. Can I place top and bottom wires to and from the same part or do I need to use a via? Can i route both top and bottom wires to and from the part even if the part is mounted on the top layer and soldered only on the bottom layer?
What I want to do is drag a bottom wire to a header pin or potentiometer and use a top wire from the same pin. Is that possible without using a via?
