Has anyone got this DC 12V 24V Dual MOS LED Digital Time Delay Relay Trigger Cycle Timer Delay Switch Circuit Board Timing Control Module?
There isn’t enough information here to make a part (that is why there is a template for you to fill in in this group.) A web site like this with the connector information, physical dimensions of the board and a flat on image of the board are required to make a part.
specifically these two images from this site:
flat image (the image above is useless!) with connections
dimensions of board: (here only the measurements matter not the angle of the picture.)
that results in this part which should do what you want. Note pcb view has been suppressed as not useful.
LED-digital-time-delay-relay-module.fzpz (17.5 KB)
Perfect! Thank you so much! I appriciate the quick turnaround.
