The best attempt at making LM723CN
The best attempt at making a fritzing component… does anyone know how to do it better, and take advantage of what was already there?
If yes, please download the best edition of this component.
LM723NC.fzpz (7.7 KB)
Schematic in this part is lacking a lot of pins. A better job can be easily done by editing a generic IC
If you drag in a generic IC, set it to 14 pins then click Edit pin labels you can set names for the various pins. You could also make a custom part but that is more complex (and no one appears to have done so yet.
vanepp, Thanks for the explanation, I’ll try it and then share it here to see if everything went well…
