Terminalblock - TDPT 2,5/ 4-SP-5,08
1017505 - terminalblock TDPT 2,5/ 4-SP-5,08
https://www.phoenixcontact.com/en-us/products/printed-circuit-board-terminal-tdpt-25-4-sp-508-1017505?type=pdf
[X ] Other (please specifiy)
Connector
Not sure
For future reference, what is needed is a data sheet with the pcb footprint (which isn’t in the data sheet you provided) like this from digikey
specifically the drawing on page 6 which gives the layout and positioning of the pins.
from that I made this part which may do what you want. I was lazy and didn’t do a 3d representation in breadboard but rather the easier flat version (I can change it to 3d if you need it for something though.) I am assuming the 2 pins connect together internally in this part.
phoenix-1017505.fzpz (4.0 KB)
