Hello guys,
does anyone have the Teensy 4.1 part for Fritzing without the upward pins?
Thank you!
There is a teensy 4.1 part here
you would need to define what “without upward pins” means. The part has pads and thus no pins.
Hello @vanepp , thanks for your reply.
I meant the pins that are not on the main parallel rows, more specifically USB Host, Ethernet, {On/Off, Program, GND, 3.3v, VBAT}.
Unfortunately my Fritzing editor is not working otherwise I would make it.
Let me know
Thanks
I am still unclear on what you are requesting. It sounds like you want these pins in pcb deleted (which is possible) is that correct?
Correct!
Unfortunately my Fritzing editor doesn’t work properly otherwise I would give it a try.
Even if parts editor was working for you it can’t do this. It requires editing the .fzp file directly to implement (along with the pcb svg,) This part should do what you want. You can still connect to the middle pins in breadboard and schematic but not in pcb.
Teensy 4.1-no-middle-pins-in-pcb.fzpz (20.1 KB)
