Hello, this is my first post on this Forum … Sorry if I make mistakes ![]()
Has anyone tried to wire an arduino to a T6 AC servo motor like this one ![]()
https://www.oyostepper.it/goods-1099-Kit-driver-e-servomotore-CA-digitale-serie-T6-da-1000-W-3000-girimin-319-Nm-Encoder-a-17-bit-IP65.html
My idea was to connect on the CN1 port like below :
driver PUL+ connected to arduino Pin 9
driver PUL- connected to arduino GND
driver DIR+ connected to arduino Pin 8
driver DIR- connected to arduino GND
and try this code to begin :
const int pin8 =8; // DIR+ driver
const int pin9 =9; // Pulse+ driver
void setup() {
Serial.begin(9600);
pinMode (pin8,OUTPUT);
pinMode (pin9,OUTPUT);
void loop() {
digitalWrite(pin8, HIGH);
tone(pin9,500); // 500 = speed by pulse?? what should be the right number to begin with (maximum bandwidth of the driver is 750KHZ)?
delay(5000);
Does that code could works ?
Can we also imagin using arduino accelStepper library to control velocity of this T6 series AC servo Motor?
Thanks
