Svg export parts missing
amazing work, thank you, how can I access to the editable svg file like you? where is it? Although I don’t quite understand why the component didn’t disappear when exporting in .svg just because they were misaligned and the distance of the terminals was poorly proportioned.
The breadboard file is the svg.breadboard.Stromversorgung Beradboard_7380d45ef141c9a49b088389af48acbe_16_breadboard.svg
file which can be obtained by unzipping the .fzpz file which looks like this when unzipped (I use 7zip):
The svg editors (certainly Inkscape) add px to the font-size attributes in the svgs which Fritizing doesn’t like, so I normally run the finished part through FritzingCheckPart.py which will both remove the offending pxs and check that the part is correctly formatted (and complain if it finds errors.)
Opened an issue on github as I think this is a bug.
Linear gradiant renders in Fritzing but doesn’t export as svg. #4195
