I would like to see option to have raspberry pi pico in the coding which would be python based as this is a easy to learn coding and could be helpful for new people of course this is just my suggestion
It should already be possible to put python in the code tab. It is just not possible to ‘execute’ it from there. For the microcontroller based python implementations I am aware of, the device is configured as a usb flash drive, and the python to be run is put in a file in a specific location on the flash drive. There is no way I know of to directly run python code from something like the code tab of fritzing. The code needs to be copied to a file on the device. It should be possible to create a tool that does the copying, instead of needing to do the copy and paste.
Mirco Merlin what I mean is it would be nice if in the code section you could select something other then the 2 current arduino or the PiCaxe offer a options to add more to that sections
