does anyone have this fritzing part already the github Adafruit one is not the right screen it has ten pins. If not can someone make it? Thanks in advance for any assistance!
Does it look like this (otherwise a web site with the specs would be needed …)?
yep that’s it exactly
This part should do what you need. If you want mounting holes you need to drag a hole in to your sketch and place it over the mounting hole in pcb view (which is only on the silkscreen and will not by default be drilled.)
lcd-color-display-0.96in-80x160-8pin-interface.fzpz (5.7 KB)
Thank you for your assistance Peter!
