SSR D2425 parts help
Hi all,
I recently found this app and it’s a huuuuge help! Thanks every contributor!
And I do need the part D2425. Thanks a lot for people helping me!
Spec as below:
https://www.digikey.com/en/products/detail/sensata-crydom/D2425/139477
@ann80325 When do you need this part by
Hi I’m not in a rush but maybe in 1-2 weeks? Thank you so much!
Do you need that exact part, or just a solid state relay with the same form factor (e.g. FOTEK)? A search on this forum for just SSR returns a couple of options if the latter is all that is required. If one of those is OK at the schematic and PCB level (I would expect them to be the same), then it’s probably not so difficult to create a new part with the specific breadboard image.
Maybe just make the module. Safer that way. Not that much energy required too
Here you go…
SSR-crydom.fzpz (42.1 KB)
