Part of SRPassives EC12E20-24P24C-SW Rotary encoder with push button.
Technical datasheet is available here: https://www.tme.eu/Document/3355ee49dae2859b0bf824db7ca698f7/EC12E20-24P24C-SW.pdf
Rotary Encoder Pushbutton.fzpz (6.6 KB)
Again schematic is incorrect in that it isn’t aligned to the 0.1in grid as it should be.
The square holes in pcb also won’t be drilled.
There is now an overworked version:
Rotary Encoder Pushbutton.fzpz (6.8 KB)
