Hi all,
I want to use SRD-12VDC-SL-C on my project. So I edited from SRD-05VDC-SL-C to SRD-12VDC-SL-C but seems like the part doesn’t match with datasheet. I have plugged the part to my pcb but it’s hard to get the part fit with the pcb. I need to bend the terminal to get through the hole but it can’t fit perfectly (still have gap between the pcb and the part).
What I have found here:
The opening for COM pin is not matched.
The spacing between COM and Vcc/Gnd not matched.
Anyone please help me to update this part to match with the datasheet and create new one with 12V version.
Here the fritzing part file:
SRD-5VDC-SL-C.fzpz (10.5 KB)
Below is the datasheet for SRD-12VDC-SL-C
https://www.alldatasheet.com/datasheet-pdf/view/1131947/SONGLERELAY/SRD12VDCSLC.html
Thank you.
