SPS30 sensirion particle matter sensor
Hi I’m new to fritzing and I need this particle matter sensor. I can’t find anything similiar, I can only find UART Rx/Tx dependant PM sensors like PMS5003.
Datasheet: https://cdn.sparkfun.com/assets/2/d/2/a/6/Sensirion_SPS30_Particulate_Matter_Sensor_v0.9_D1__1\_.pdf
A google search of the form “fritzing part sps20 sensiron particle sensor” turns up this part which appears to be mostly the same (yours has one more pin which doesn’t appear to be used.)
If that doesn’t do then you need to fill in the template which asks for a web site with physical dimensions and connector information (your data sheet reference gets a 404 response for me.)
