Sparkfun Pro Micro RP2040
I am looking to build some projects with the Sparkfun Promicro using the RP2040 chip:
I don’t think there is a part for this yet, or am I mistaken? (I am new to fritzing)
These two parts should do what you want. For through hole (which will drill holes for 0.1in connectors in pcb) use this:
sparkfun-pro-micro-rp2040-THT.fzpz (18.8 KB)
for SMD (where you want to solder the pads to the board) use this:
sparkfun-pro-micro-rp2040-SMD.fzpz (18.7 KB)
